Help guys please! 97 toyota 4 runner
oahu
Hey guys my 97 limited 4 runner 2wd wont go in reverse but works only sometimes but mostly not. The other gears are fine….What should I change? Or look at
Also If you guys know what it could be what is the steps to access it
If you mean your automatic transmission will not engage in reverse, then check the fluid per the owner's manual (hot transmission, engine idling in Park) and/or change the fluid and filter. Those are always the first steps in transmission diagnosis. If you pull the trans. pan, pay close attention to the 4 magnets in the bottom of the pan and any other metal or debris in the pan.
