Help, FSM's @home, stock vehicle height?
Discussion in '80-Series Tech' started by GeoRoss, Aug 2, 2005.
  1. GeoRoss
    GeoRoss
    1,952
    1,410
    Dec 4, 2004
    Tucson AZ
    I am in the process of building a carport (maybe) and I just realized that I may not be able to fit inside after the 2.5" med. OME lift I am planning for sometime in the future. I have some leeway on the design, but I can't just make it 9ft high, the roof can only reach 7'6", not including the beams (2x8's or 2x6's).
    I am running BFG285/75R16 right now (33's) and with the 2.5" lift I am guessing about 3-4" over stock. I haven't removed the stock luggage rack, but have plans for taking it off. I don't have my FSM at work. Can anyone tell me the stock height of a FZJ80? I searched and searched and didn't find a single answer, mostly just the lift height and some about now not fitting in the garage, something I am trying to avoid.
    Just trying to prevent a trip home as I am suppose to secure the permits today, editing the site plan as we speak.
  2. Rookie2
    Rookie2
    3,042
    90
    Dec 15, 2003
    Knoxville
    This probably doesn't help, but I went out and measured my stocker, and the top of the roof rack crossbars, is around 74 1/2". I'm on 8 year old factory springs and I'm sure I've got a little sag going on.
    :beer:
    Rookie2
    Edit: Oh.., and I'm on stock tires, with about 40% tread left.
  3. GeoRoss
    GeoRoss
    1,952
    1,410
    Dec 4, 2004
    Tucson AZ
    Thanks, is that with 33's or stock tires? Anyway, it looks like I'll be using 2x6 cross beams.
    Ross
  4. tiorio
    tiorio
    378
    1
    Apr 11, 2003
    Funny timing. I made a late-night trip last night to check various parking garages...
    97, factory rack, OME 2.5, 285s, 20mm trim packers up front, ARB bull up front...
    Three garages:
    CLEARANCE 6'9" - had about 2-3 inches left
    CLEARANCE 6'5" - had maybe an inch left
    CLEARANCE 6'6" - 1 inch TOO SHORT...
    someone's lying but that at least gives you a range...
  5. GeoRoss
    GeoRoss
    1,952
    1,410
    Dec 4, 2004
    Tucson AZ
    Thanks for the replies. I have plenty of room and now the LC won't have to sit out in the sun, or under a tree getting bird poop all over it.
    Thanks again
    Ross
