Help Fixing Leak (1 Viewer)
Anyone know what's leaking here? It's below the passenger door close to the front wheel well. It looks like green coolant, my coolant is red though. I still have the hydraulic suspension, so I'm thinking it might be that.
Thanks in advance.
That is the ill-engineered A/C corrosion-bomb behind the RF tire on 100 series. My steel 'shield' rusted away (not sure it did a lot of good), and I greased all the aluminum lines where they went through rubber fittings, etc. and were starting to see corrosion. I think your fix is to replace that hard line, study all other lines for similar corrosion, and recharge the A/C system.
At least you found the AC leak =]
Thanks for the feedback. I'll tackle that this summer after the timing belt.
Also, there is a small kit for redirecting the condensation to help avoid rusting out the passenger side sway bar bracket area.
