Wanted HELP...Engine Parts Needed For 1970 FJ40
Status
Not open for further replies.
Flagstaff, AZ
I need: crankshaft pully, carb (just had a big SNAFU with mine, I was in the process of rebuilding), alternator (working), alternator brackets, water pump, oil pump, and I am sure I need other things that I cannot think of right now. Hell if you are relatively close I will even buy an engine off someone that is doing a v8 swap. Just let me know if you can help.
Darrin
Flagstaff AZ
dfblackm@yahoo.com
I have an Asco oil pump see pix and an alternator with a narrow pulley. Pump appears to be in good condition but I have never used it. Alternator was working on my 73 F when it crapped out. $50 plus shipping for both
I have a complete running 1973 engine,but it's in Pittsburgh. Don't if this will help, but I will sell parts off of it. Let me know.
Mark
Ok well I posted a big newbie post on the 40 questions section. So I actually have an F engine with a 3 speed trans/vac asst t-case. So once again I need several engine parts. If you head over to the thread on the 40 questions you can see pictures of my engine/or lack there of.
What I have:
Block (pistons, head, cam) (pulled the valve cover and front cover, everything is well oiled and lubricated)
Dizzy
Oil Pump (don't know condition)
So I need for an F engine:
Crank shaft pully
Water pump
Alternator Brackets
Alternator
Carb
Fuel lines
Oil lines
Starter
Now if you have these things lying around and don't know if they work, that is fine, some things I would like in good condtion. The pulley would need to be in good usible condition. I would like for the lines to be in decent condition. As for other things if you want to just send them out to me and I pay shipping that is fine, granted I don't want a pile of junk but I can use this stuff to dummy up the engine.
Thanks for all of your help.
Darrin
you have part of the F alt bracket. looking at the motor from the front it's to the right of the crank bolted down on the side.. all you need is an alt and the other flat stock piece for belt adjustment.
Status
