Hello everyone in the house, I need help solving my high fuel consumption issue on my LC 2000 year v8 4.7l 2uzfe with 177,000 plus.
Scan the car with gs500 scan tool with no check engine light and no codes.go through the live date with following : SHRTFT1-3.7, LONGFT1-19.0, SHRTFT2-4.7, LONGFT-17.6
After watching some YouTube video that says it is related to vacuum leaks, I checked all through the hoses with no leaks then I have to rethigten all bolts on the intake manifolds, clean the Injectors and spark plugs.
When I restart the car and check live data, the shrtft1-1, longft1-8, shrtft2-0.8, longft2-6. When I unplug the MAF connector the car will die down and when I restart the engine running the live data longft1 & longft2 went up.
Questions-- is the engine suppose to die when the MAF connector is unplug,
I also tried using the Techstream, it scan the engine when engine is off but cannot connect when engine is running, what can be the problem.
The Gs500 scantool scans the engine running and gives me live data. I cannot attach the video saying does not allow the extension don't know what it means.
Thirdly, can anyone tell me how the hose connection to the fuel pressure regulator works? Does it suck in air or push air to the fuel pressure regulator? If I remove the hose from the fuel pressure regulator it does not make any difference on the engine either increase or decrease the engine speed. (hose circleon picture)
I am doing all this as I don't have enough money to just throw in parts.
FYI- all spark plugs and coils are brand new replaced when it was given misfire on some cylinders and all stops with no codes. Injectors all serviced too.
I will appreciate all suggestions thanks in advance and please sorry for the long writings.
