hi guys, some might recall that i recently replaced a 3b-t with a 15b-f. since then its been running pretty good with the only issues being a leaky top seal on the inj pump. ive also fiddled with the fuel screw but pretty much put it back to where it was originally.i say pretty much because even now it is overfueling a bit. its not rolling coal but noticable in the side mirror under load.
today i pulled the first real load of about 1ton of firewood. everything was going ok and i was taking it easy. theres a 2 long hills to get up to the house as we live near a ridge line. The last bit of the drive way is a right angle at the top of a long sweeping uphill bend.
I kept it in 2nd since the start of the first hill and it smoked a bit more than usual getting up there.. speed was pretty moderate up to the last corner but as its loose gravel just made sure the rpms were up...
the engine seemed to have a bit of a tick coming up to the corner, it then dumped a big plume of black smoke followed by a real dense while smoke which lingered in a large cloud.. i popped the hood to blip the throttle trying to see if i could reproduce it but couldn't.
Water temp was about 185f on a 82c themostat at the top of the hill, didnt check the oil pressure tho
I fumbled with my phone to try and get a photo of the cloud but it had dispursed a bit by the time i took this photo
from what i know about smoke colors, black is over fueling.. bit confused about the sudden onset of white though, always thought it might be a air in the fuel or a head gasket?
I still need to adjust clearances, confirm the timing and check radiator for oil, etc. not sure what else it could be something munted in the injector pump..
I did refuel this morning too but not sure if it could be related.
Any ideas would be appreciated.
