Help! Crank bolt removal....
Clemmons, NC
On a 91 3FE....water pump started spitting out the weep hole, so I decided to replace it. The timing cover had been leaking slowly even since I got the truck, so I figured now would be the time to replace the timing cover seal.
I have everything ripped apart, except the crankshaft pulley. I have the 1 13/16th"/46mm socket, but cannot figure out how to "jam" up the motor. I took off the inspection plate, but I couldn't figure out to position any kind of tool in there to stop the motor.
So my question to everyone is...what are my options?
1. Borrow a big 3/4 drive impact gun?
2. Block the breaker bar and crank socket, and kick the starter over? (Will this damage the starter?)
3. Somehow block the ring gear?
I am going to speedi sleeve the timing cover seal if I ever get to the damn thing. Any insight would be much appeciated!
Also...anyone know the torque spec for this crank bolt?
I usally use a chain wrench around the crank pulley, use a piece of old timing belt to protect from marring. This way works good but can damage the rubber isolator between the inner and outer parts of the rank pully if they are old and rotted.
Brian
If you can find a reliable (won't slip) way to jam your wrench on the frame, etc then that technique works well. Absolutely no danger to the starter. Just secure the wrench with tape/wire / zip ties etc so it won't slip. You can use a pipe over the wrench to lengthen it. Also, pull the FI fuse so it won't start on ya and just a bump as quick as you can is all you'll need to break it loose.
DougM
Thanks for the quick replies guys! I'll try the starter trick first, if that doesn't fly I'll give the strap wrench a go. Anyone have an idea what the torque spec on that nut is supposed to be? I have heard 295ft/lbs?
Not sure about the 3FE but the 1FZ-FE is 305 ft-lbs.
You shouldn't have a problem getting it off, but it is more of a job getting it back on and torqued up to spec.
When you use the starter make sure your distributor lead is disconnected. I've done this twice and used webbing to hold the breaker bar tight against the underside of the frame (PS). I used a 24" 1/2" breaker bar slipped into a 3 foot length of iron pipe I had laying around. One snap on the starter and it broke free like a charm. George Scolaro has some info on his site under the supercharger install (http://george4wd.taskled.com/scharger.html)
Good luck
If it helps, here is a very simple jig I made to hold the crank pulley from turning. Center hole is 2 1/4". The small holes are about 3 1/2" on center. Scrap plate is 13" long X 6" wide X 1/4" thick. Bolt plate on and let it hit on either frame rail to stop crank from turning. Big socket fits through center hole.
Bill
I used the starter, but I had a weak battery and it took several hits of the starter without success. Stalling the starter at the same point several times burned the contacts. Luckily I had a set of contacts and a new battery to put in, success was had. Getting the bolt torqued required a pulley tool, mine ended up a little fancy since I have a machine shop handy. 305ft-lb was just a guess, I figured it wasn't critical.
Any good 1/2" air impact wrench (like an ingersoll 2131) shouldn't have trouble removing the bolt. Getting it back on to exactly the torque spec requires you to block the pulley.
Cheers
Bill
I like this approach, I will be making my jig tommorow! Thanks for all the help guys!!
I did the starter bump trick on my FJ62, worked great:
Pretty sure the torque spec is 254 ft-lbs. I had my oil pan off at the same time so I wedged a chunk of scrap 2x4 between the crank and the block to keep it from turning while I torqued it back down.
landtank said:
What makes that torque spec a little critical is that you basically drive the oil pump and power steering pump by friction. That bolt clamps a non-keyed gear in place on the crank. If there isn't enough clamping force you will loose drive to those 2 pumps.
You must be thinking of the 1FZ. The oil pump on the 3FE is driven off the bottom of the distributor (which is driven by the cam), and the PS pump runs off one of the belts. The crank has a key on it to index into the crank pulley.
