I am in the middle of swapping a 1977 front axle under my 1972. The center pin on the Skyjacker lift springs for the 1972 axle is a bit too big to fit in the 1977 spring perch center hole on the axle. I realize that it would seem there are different size pins, but my 1977 axle seems to have a extra plate welded to the perch?? There's the perch... and a plate welded to that. Is that normal? Should I grind the welds and remove the extra plate, or just ream the center pin hole and keep moving forward?
Just don't want to screw something up... pics to follow!
