I was wondering if anyone in the Toms River NJ area can tune my carburetor 79 FJ40. $ Will Pay for your assistance.
It's oem looking Asian carburetor. It runs and can drive it. Need to slightly choked to stay running smoothly and from the exhaust tail you tell it's just not correct . It would probably take someone with the knowledge 10mins. to adjust it. I just don't want to make it worse or bring it to the point of no return . Oh it's a 79. Thanks..What year, what carb, what's the issue? Lots of guys on here that could probably help with some basic information.
Thanks for the tip / adviceProbably not something that can be adjusted away; the only things easily adjustable on these carbs are the idle air mixture and the idle speed.
The first thing I would suspect given your symptoms is a vacuum leak; at the base of the carb, at the intake manifold, or at the brake booster. Spray some carb cleaner or wd-40 on these locations with the engine running; if the rpm varies when you do, you have found a vacuum leak.
This video is very helpful. Search lean drop method which is what he's illustrating
But, Where/ How do you hook up the digital tachometer?
Thanks, I want to try it.Usually on the negative terminal of the ignition coil.
