Well dang if this isn't a pain! I have a complete front axle from an '83 toy pickup for a disk brake swap onto my '71 fj-40. I have already removed the passenger side knuckle and axle assembly on the '40 with no issues. I have removed everything on the passenger side of the Pickup axle EXCEPT the inner/outer axle assembly. I cannot get it to budge. as a matter of fact, it appears as though I could pop the birf off if I could get a good whack at it...(not gonna even TRY that , eheh). It is just plain stuck. Yes, yes I am sure I have the flat sides up and down. The Cruiser ones came right out. It appears as though something is bad/ stuck inside the 3rd member...but I just can't figure this out.
I can only think of a couple of options here....Use a torch and cut the axle housing/inner axle...(I don't have a torch). Remove the driver's side and use a long rod to smack it from the drivers side( is that possible?).
Any thoughts???
Mike
Any thoughts???
Mike
I have been trying to figure a way of prying...that is how I got the birf out as far as I did. I will attempt that first. Ido not have a need for the housing, so IF I have to, I can cut it up.....ah the things we do for our toys...hehe.
