Help: alternative for shut off valve bj74?
Socal
Seems its time to replace my shut off valve of my bj74. Clutch is hard and valve isnt cooperating. Tryinf to find a replacement part for it but no luck...
If your clutch is hard, I’d look for a vacuum leak somewhere else rather than replace that valve. Intake gasket? Vacuum hose cracks? Vacuum pump going out?
I had a leak in my intake gasket which caused my BJ74 to not shut down right.
You can check that valve with a vacuum pump /mitt-vac.
The shut off valve looks like it is available through Amayama. But, I agree with FJBen that a vacuum leak is a much more likely source of your problems.
