Help! All windows being triggered, and its January...
UT
I have done an initial search, and my search terms were probably flawed but I changed out a fob housing for my '08 200 and its triggering all the windows, including the sunroof to open. And a red light is coming on on the fob. Obviously I did something wrong.
What did I screw up? Its January, my Cruiser is sitting outside and snow is coming, not to mention below freezing temps. I'd love to get this figured out...
Thanks
Blixen
Holding down the unlock button is what triggers the window/sunroof opening when this feature is enabled with Tech Stream. When switching the key fob housing, you may have inadvertently got the unlock button on the key fob internal board stuck down maybe with the rubber pad?
That's a setting that can be disabled, but you'd be better to fix the problem instead. I also bet you have a jammed button in the fob.
