Hello everyone,
Thanks for taking a moment to read this. I have a 2006 LX470 - 250K miles with Slee AHC chip, diff drop and SPC UCAs, on 295/75-16s. I've been having issues with my front suspension as a whole and can't figure out if it's just time because of mileage or if it's because I'm running AHC which doesn't always stay in the same height position. I previously had the passenger side axle leave the car immobile, at that time I replaced the passenger axle and oem UCAs to SPC. Today it happened on the driver side. Mechanic says there is movement in the steering rack that will likely need to be replaced in the future and the driver side axle needs to be replaced immediately. Any insight or advice is greatly appreciated. Just wanted to cover my basis and see if it's time due to mileage or if it's my current setup. If you were in my position, would you continue using OEM replacement axles or upgrade them? What are upgrade options you would recommend? Thanks in advance!
