Hella 500 Wiring Problem...
Discussion in '60-Series Wagons' started by 03s54, Jul 5, 2013.
  1. 03s54
    03s54
    20
    Apr 30, 2012
    Hello all! I recently bought an FJ60 and have been working on it for the past few days to get it at least to a maintenance level that I like.
    I spent some time pre-wiring the Hella 500 wires and I am having some issues with the lights not actually turning on with the switch. I will attach pictures from what I have, and see if anyone can chime in as to something obviously wrong?
    I have the two blue grounding wires from the two lights spliced together (with some black wire) and at a contact point in front of the radiator. I then have the black wires spliced with the black wires from the relay.
    From the relay, I grounded a blue wire to a screw on the right-inside of the engine bay. Then from the relay, I have a red wire that connects to the positive contact end of the the battery, and the yellow wire goes into the rocker switch inside the car.
    So from the rocker switch, I have a yellow connecting to the relay, a green wire connecting all the way to the battery, and a blue grounded at a screw by the rocker switch.
    Keep in mind i have 1/2" corrugated plastic to wrap all the wires once it's figured out to make it look pretty...
    Thanks for your help guys!
    Here are pictures of it as well:
    Switch wit h blue ground, green to battery, yellow to relay
    [​IMG]
    Back of switch to show wires
    [​IMG]
    Firewall
    [​IMG]
    Relay's blue ground
    [​IMG]
    Relay just chillin' there
    [​IMG]
    Black wiring from lights to relay
    [​IMG]
    Ground wire to metal from both lights
    [​IMG]
    Connection to battery for green from switch, and red from relay
    [​IMG]
  2. Benjaman
    Benjaman
    1,537
    Media:
    9
    Albums:
    1
    75
    Jun 20, 2010
    Walker Lake, Nevada.
    I cant make out what you've done, but I would not run a hot lead thru the firewall. The only power needed to the switch, is to light the LED in the switch. You should run a ground thru the firewall (from the switch)and use that ground to trigger the relay(85).
    Keep the relay near the battery,Run a positive(fused(25 amp)lead from the battery to the relay(30) and run 10~12 gauge positive from the relay(87) to the lamps. Ground the lamps at the mounts. Piggy back a short lead of 14~20 gauge from the relay(30) to the relay(86).
    Thats it! you've got light!
    Cruzerman likes this.
  3. ravenplague
    ravenplague
    235
    182
    Jan 3, 2015
    Santa Cruz
    my Hella switch was not working at all straight from the box! i went to autozone and picked up another...
  4. Fj moneypit
    Fj moneypit Cubic Zirconia Member
    723
    Media:
    17
    Albums:
    4
    341
    May 11, 2013
    SoCal
    I'd first start by cleaning your battery terminals!
    [​IMG]
  5. Cruzerman
    Cruzerman
    2,020
    386
    Apr 23, 2005
    Oregon
    Exactly what Benjaman said, which is slightly different than what Fj's diagram shows. In the diagram, the lights will only work when the highbeams are on. Also, it shows running power from the highbeam into the switch. I agree with Benjaman that you should use the switch for ground and not for power.
  6. cruiserfj45
    cruiserfj45
    1,450
    163
    Mar 12, 2003
    Fresno, CA
    I run the my KC's like FJ moneypit's diagram so when I am running them in the mountains I can turn off my high beams and kc's with one switch when I see some lights coming around the corner.
  7. KLF
    KLF Frame waxer SILVER Star
    7,385
    2,030
    Apr 5, 2003
    Southern NH
    I would start by throwing the switch in the trash, get a better one. The ones they supply in the kits are garbage, if it hasn't failed yet, it eventually will.
  8. SHERMAN FJ62
    SHERMAN FJ62 Charlestons' King of Cruisers
    1,756
    43
    Jan 29, 2008
    charleston
    Try a new contacts and make sure your grounds have contact with bare metal. I have these lights on two of my trucks and that have been the issue with mine.
  9. Chris8760
    Chris8760 SILVER Star
    143
    153
    Dec 10, 2013
    Georgia
    +1 here... I installed these same lights and could not get them to work. I went over my wiring multiple times... As a last resort I decided to try a new location for the ground... Instant fix. I wasn't getting bare metal. I was using a threaded hole in the engine bay covered with factory paint. Hoping it's this easy for you...
  10. ravenplague
    ravenplague
    235
    182
    Jan 3, 2015
    Santa Cruz
    I mentioned before that i went to autozone to purchase a new switch for my new lights and realized how much that blows especially coming from a reputable company. So I sent the US distributors an email and they responded immediately. They said they would send me an upgraded switch asap. Ill post pics as soon as it comes in.
    Send an email and let them know their switch sucks and they'll send you a new and better one...hopefully
