i've been here before about bad handling , but still things are not good.
HDJ 100 4,2 D, 200 k km , manual 5 speed , ahc , 275/70 16 -100% stock.
Problem : The truck will not go down the road straight , and making smale corrections at 60 mph is so heavy, you almost need 2 hands on the wheel. When she comes -she comes - be ready to counter steer! Also you feel just about everything the tires run over. On gravel it feels like a wheel or something is lose. But nothing is.
Over the years, I have replaced every ball joint , bushing (front and rear ,upper lower) , last the steering rack. The truck is tight as ever.
Toyota has had it in the shop a few times now , but they haven't been able to figure it out. They are going to do a new alignment when people get back from vacation.
I'm thinking they maybe did a bad alignment last time (to much tow in/out ?) when they replaced the rack .And that might be why it won't go straight .The caster /camber marks are in the normal range.
But why i feel every little bump/ridge in the form of a wiggle in the steering wheel, is strange . I don't feel a thing in my volvo s-80 on the same roads. The steering wheel also pulls left or right on most roads that are not perfect. very neutral / unstable - if you know what I mean.
Could the power steering pump be bad ? Low pressure ? Standing still, lock to lock ,it is a bit heavier than a 2011 120 LC i tried. The power I do have is smooth/ constant , no pump noise or leaks. Going slow or fast the whole steering has a rubber feel to it - like the steering wheel want to go back a little ,when letting off the pressure.
Other than this , Its a great Truck ! Thanks for any help here .
