Seeing as it's winter time I thought I would add my 2 cents about the automatically contolled heating system. If you are having problems and your heater core is not plugged, then the water valve and blend door servo motor is the problem.
The flow of coolant to the heater cores is controlled by the water valve on the fire wall. If the cab of your truck is too hot in the summer chances are this valve is not closing completely and you may have to help it by disconnecting the cable and shut it manually to stop coolant from entering the cab.
The opposite is true for people not getting enough heat. You may need to open it up further to get more coolant flow. This valve is controlled by a cable connected to a servo motor (climate controlled trucks) that is located in the worst place to work on when you need heat in a hurry. (i.e. in the parking lot with the wife in a blizzard).
This same servo motor also controls the "blend" or "air mix doors". They route the air entering the system "to" or "around" the heater core.
If the servo motor doesn't move far enough you will get coolant to the heater cores, but the position of the blend doors won't change. This means the rear heater roars like a fire and the front heater puts out little heat and the side and front vents freeze you out of the truck. If this is the case grab the vice grips and pull the cable a little further this will change the position of the blend door and push more air to the heater core giving you more heat up front.
This will get you on the road again. When your ready you can decide if it's worth it to change the servo motor. The servo motor is located on the back side of the heater (facing the fire wall of course) and you have to strip the truck inside to get at it. It's not easy to work on. So if your in a bind play with the valve manually and/or give the cable a little "help" with the vice grips to move the position of the air mix doors.
Driving in a cold truck in Canada sucks.....
