Heater problems
Pa.
I have a 74 40,that would get so hot ,you couldn't touch the front or rear heater.The temp gauge was right in the middle though.I had a leak in the radiator,so I replaced it with one from ccot,along with the thermostat,both gaskets,heater valve,and every hose under the hood.After starting it up,and running,the temp gauge goes to the line past halfway,the heater in front will get hot,than cool down,and the rear heater hardly gets warm.What did I screw up this time?!!! Thanks.
Sounds like you have a very effective radiator.
Nah. How about, your thermostat isn't closing, or you forgot to put in that gasket that goes at the top, so the temp is falling below 190 or 180 with your very effective radiator.
And, perhaps you pushed some sludge into your heater cores when you changed things out.
I'll check that tomorrow.I did put the gasket on top of the thermostat. I'm also wondering if I have an air pocket. There didn't seem to be any sludge,as the coolant was pretty clean.
In going through some old posts,one thing I didn't do,was to open the the valve on the motor to drain the block. I'll check these things out tomorrow. Thanks for the info!!!!
sounds like you have air in the system, get the front end up in the air(park on hill or jack it up) leave the cap off and let it run with both heaters on high..........that should burp the air out.
That was it!!!!!! I took the cap off and let it run.After it cooled down,I added some coolant,put the cap back on and now the temp. is where it's suppose to be and the heaters work great.Thanks for all the help!!!
i need to try that out too
a couple days ago the temp went up and i loosened the rad cap and it was crazy pressurized/hot.
i think i might have some air in there (and the loose belt on the water pump probably doesn't help, ha ha)
anyways, i got the belt on order finally (amazing what you can do when you acutally have money)
and it should be here tomorrow.
finally gettin around to fixin all the stuff that needed to be done 2 months ago
malphrus
good deal :) see ya didn't mess anything up..;)
