I just pulled the carb on my FJ60. The vehicle has 205,000 miles and is new to me. I had an awful whistle coming from the drivers side of the engine. Someone on here on another thread recommended retorquing the intake manifold bolts. I am trying to get to these and so I pulled the carb and now I am trying to get the damn heat shield/carb spacer off of there. It looks like my intake leak may have been where this heat shield/spacer meets the intake manifold (see picture). It looks like the heat shield/spacer removal (and proper reinstall with gasket compound?) would be easier if I removed that air line that connects each cylinder (technical name for this?). I loosened the top nut on each cylinder line but it does not pull free.
Do I have to loosen the portion threaded into the cylinder?
Also, I noticed that when I pumped the accelerator only the passenger side barrel of the carb gets a spray of gas. Is that normal? Should I rebuld the carb while it off?
