I did a search on this and kinda got an asnwer but still wanna throw it out there to see if I missed anything. My temp guage in my 40 ran between the first line with the c above it an the next hash mark all the time regardless of outside temp...driving highway speeds it creeped up a little but never much. The hoses were some f'd up mix of hoses from something else that were cut to fit and on the way out so I replaced everything with new. Removed the rad drain plug and nothing...the hole was blocked with black hard crud so I took piece of coat hanger and gently got it to break. drained everything, the coolant looked fine. After replacing hoses, thermostat , both gaskets and temp sensor with oem stuff from the dealer I filled it 50/50 with coolant and went for a ride. no leaks but it drives way hot. the temp guage gets hot within a mile...never did that before. hits straight up and creeps towards the last line regardless of speed. I know the guage is right because I cant hold the upper hose for more then 2 seconds right after I turn it off after a drive cuz it is freaking hot. I thought maybe the radiator was to blame...but it worked fine before...bad thermostat out of the box? What do you guys think?? any suggestions?
