- Thread starter
- #61
So....Off we go.
The first thing to do is to remove the old lights. This is done by removing the center grill (phillips head screws) the side markers (phillips head screw at upper corner of light and locking pin on bottom) and signal lights.
When removing the side marker(if yours is a pain in the butt like mine) you can use a 2 ft long dowling about the thickness of a broom handle to push it out through a hole that exists in the wheel well. When you look in the wheel well you will see a black plug; remove that to expose the hole.
If you are doing this on your own be sure to put something soft on the front of your bumper to ensure the marker doesn't go flying out and crack
