- Thread starter
- #21
ok cool, I will look for that fused link, if I cannot find one I am in the process of building an entire extra fuse block/relay block for all my add ons so it will be no problem for me to add a fuse and run new wires.Looks like the PO attempted the direct relay to the headlights in an effort to get more light.
This uses the switched circuit to switch the relay and there supposed to be a much larger red wire direct from a fused hot source to the relay and back out to the headlights.
The goal is to improve the voltage to the headlights.
Horribly botched job though.
I still only get light out of the headlights when the brights are on. Do you think he wired the low beams to the bright wire? I will test them to see. No biggie. I got some butt splice/shrink tube/solder all in ones coming tomorrow. Gonna see if I like them or not. Otherwise I will just buttsplice/shrink wrap. I don't think they need to be soldered.
