I have an 81 fj60, with an LED headlight set. When I bought the rig, the high beams wouldn't work, and the low beams were very dim. After a bit of research here, and looking into it, I found the contacts in the switch needed cleaning. Now I have proper low beams, but still no highs. As far as I can tell, the relay only comes into play with lights turning on, and the switch does the path for high and low beam? I know the lights themselves work properly, I made a pigtail to test them directly to the battery so I could figure out what each contact did. Also, when I put the Volt meter to the plug, I get some wonkey readings. Does the dimmer switch tie into the headlight switch somehow, and my problem is there? The Haynes manual I have shows a red/white wire that connects it to the switch, as well as the headlight relay. Thanks for any input.
