headlight washer repair?
Durango, Colorado
Website
www.durangomagazine.com
Anyone else have problems keeping washer fluid in their headlight washers? Gravity seems to be getting the best of mine. They slowly leak out all the fluid out the sprayer. What do I need to replace on them to get it to stop?
I'll second this question. I've had this problem for quit a while and haven't been able to figure it out.
Down at the bottom by the radiator the lines enter a plastic "L" fitting to make the bends to the headlight sprayers. These 2 plastic "L"'s are actually check valves that keep gravity from draining the resivor. I went through my whole system to solve this problem and found my check valves were toast. I scrapped it all and sold it on ebay because I couldn't clean the valves and didn't want to pay what SOR was asking for them.
Check Valves I wouldn't trust used ones seeing how they are just plastic and rubber which time really takes a toll on.
I have the same problem and am looking at an electric valve from a RV/Marine store. Same price as the check valves from SOR but much more positive shutoff and shouldn't wear out. Figured I would place it inline and hook it to the washer pump wiring to be energized whenever the pump runs. On my list of projects but just not high priority.
THERE ARE HEADLIGHT WASHERS????? Damn...I was wondering why i had three washer fluid reservoirs. Where is the button for that bad boy??
I am such a noob... :rolleyes:
headlight washer button
Well...there's no separate button to activate them. They will spray the headlights only when the headlights are on.
Yeah - that was a fun one after I put in a whole new reservoir and the thing didn't work (AAARRRGFH!) ....until about an hour later when frustration was reeallly high... I was in front of the rig and my buddy, by chance, threw on the lights....D'OH! That lightened up the moment, for sure...
HTH
CardinalFJ60
I'm having the same problem. One day mine drained what looked like gallons of fluid on the ground...freaked me out, my first thought was leaking coolant or oil or something. I'll take a look at my valves.
Thanks
That L shaped elbow behind the spray nozzle is a check valve.
There is a ball & spring inside the L.
The ball will corrode (rust) and not close.
If take apart, it will not go back togeather . . .
Search internet world for "Flow Restrictor" or "Check Valve"; you'll find something that will work.
Where exactly is this "headlight washer button" located??? I was looking for it on SOR, but no luck. Can anyone help, cuse i dont have my 60 in front of me and i am too impatient to wait until i go home... :popcorn:
If you turn on your headlights and push the windshield washer button you should get washer sprayind on both the windshield and the headlights.
No button, if your headlights (or marker lights) are on when you spray the windshield, then it sprays your headlights too.
Does anyone know what year they started putting headlight washers in? My 82 does not have that option.
Another thread showed up about the headlight washers, so I searched and thought I'd bump this one- This is one of the only things not functioning correctly on my 87.
Does anyone have any new information about the "L" check valve leaking? A reasonable replacement?
(Before someone comments- YES, I know this is an old thread. My 60 is old, too, but that doesn't mean I'm going to get rid of it and get a new car!)
