Headlight switch (1 Viewer)
Status
Not open for further replies.
Bushkill. PA
Website
danhenk.com
So the 1978 FJ 40 stock headlight switch is apparently unavailable. Mine is the original from 1978 and in bad shape. It's developed a short in the part that regulates dash instrument light intensity. I checked all the lead in wires and it appears to just be in the switch itself. So I need a new one, but the only ones available are pricey used ones. Should I just do away with the connector and wire in the headlights to an earlier model switch? I can get a brand new OEM one for a third of the price of a used year specific one.
I just took my hazzard switch apart and cleaned it up. I couldn't believe how dirty the inside was. I just pryed a few tabs to disassemble it. If it's not working you don't have much to lose if you take it apart.
I already did that. The headlight switch is a little more complex than the hazard, and the '78 has a stretched out spring over a semicircle and a moving bar over it. Some where in that whole system is the short
Toyota was good at cross over parts. Maybe a mini truck switch would work?
I would ask coolerman, he rebuilds stock harnesses and might know.
The "stretched out spring" is just a length of nichrome wire, like in a toaster. It has a specific resistance over a measured length. The wiper touches the coil along it's length to vary the resistance in the circuit. You can buy nichrome wire on Ebay. I doubt that the coil itself is shorted. It might be broken, which would make more sense.
Pony up for a used switch, or hack your electrical system apart and wonder why you have more problems in the future.
Status
