You need to click on the Technical Information tab and then compare the diagram on the side or your relay and part number to see exactly what function the relay is. This will give you the information to choose the proper replacement part.
Bringing this back from a dusty corner of MUD...This is a 4 prong unit, replacing the 5 prong relay that broke, but both "87" termials on the 5 prong were activated at the same time on the originally relay, and both were INACTIVE when not under any voltage.
Is what you wrote above true? 87 and 87a are on/off in tandem? Did you prove this true with testing? And since the center (87a) socket was not pinned it wouldn't matter. And and this is NOT typical relay behavior.... normally 87 and 87a are oppositely energized.
I'm confused.
Some good info here.... MAYBE the FJ60 diagram is correct for the IPF harness.
Headlight wire harness FJ60 and FJ62
Headlight wire harness FJ60 and FJ62--And now for FJ40 I have started building these headlight harnesses again. I've updated the harnesses since these prototype pictures. The harnesses I build now look a lot better. :) After 20 years or so, the headlight wiring in our Landcruisers is just...forum.ih8mud.com
