Hi, I’m having a couple problems with my headlights and instrument cluster lights in my 1982 FJ60.
First problem: instrument cluster lights sometimes don’t come on when headlights are turned on. Usually I can turn the lights off and then on again and it’ll remedy the problem.
Second problem: while driving with my headlights on, they sometimes cut out when I hit a bump. When they cut out, the high beam light on the dash will come on for a second. Then I’ll have to toggle the high beams on and return it to the running light position and they’ll come back on.
I’m thinkng either a faulty ground or a new headlight switch may be in order. Just thought I’d check to see if anyone else had experienced this issue and make sure I’m headed down the right path.
Thanks!!
Thanks!!
