So I had my F2 head serviced because it has been running hot and everything else has been replaced. I got up and running today and it still is running hot. Saw a post to better burp the system loosen up the sensor to let out the air and it was better. When I had the head done I put in a new sensor in the back port and moved the old sensor to one of the ports on the t-stat housing. Both vacuum ports are broken off. When the gauge was high I connected the front sensor and the gauge was much lower. I know its only a range sensor but don't really want an after market dash gauge either. Could this just be air getting trapped after a good amount of time? Any thoughts?
