^^This looks like a likely culprit. Is it possible to clean the area well and run the engine and look for weeping? Its not an easy one to get to. If you do mess around in there, be cautious around all the electrical connectors (knock sensors, etc.) that are easy to break if a wrench slips. If you are able to get it out without removing the lower air intake please share. Good luck!
If it's a leaky sensor they why is it throwing a code.Looks to me like a leaky sensor. If from the head\ block interface why would coolant move upward? Truck runs fine other than throwing a code 21.
Bummer, but that’s a good run!Confirmed head gasket blown. Getting a new one. 29 years on the original.
But then you wouldn’t want a budget HG job either.Lucky to have a great independent shop here in Denver do the work. They work on a lot of 80:series and have two in the shop in addition to mine for a new head gasket. Cheap it is not
Shop has a former Slee employee that does all the 80 series work including head gaskets etc. total cost includes a significant amount of “while your in there stuff”. All OEM and comprehensive repair Including reconditioning of head.Have the head skimmed, as per my earlier post it did look like a HG, but I would reckon a minimum skim would be a good idea, it is not uncommon for a gasket to corrode and actually set off corrosion of the head itself.
Regards
Dave
I wish I had something like that near me, we have Torfab, which is incredible, but there is a significant wait!Shop has a former Slee employee that does all the 80 series work including head gaskets etc. total cost includes a significant amount of “while your in there stuff”. All OEM and comprehensive repair Including reconditioning of head.
2 80s in front in me for head gaskets. They said 2 months to get everything done.I wish I had something like that near me, we have Torfab, which is incredible, but there is a significant wait!
once you get it fixed and back you will be happy.2 80s in front in me for head gaskets. They said 2 months to get everything done.
What shop is it?2 80s in front in me for head gaskets. They said 2 months to get everything done.
