Head gasket job, trying to clean pistons but crank will not turn (1 Viewer)
mdawg
The Colony, TX
Hi, all, I'm in the middle of a head gasket job. The head is off, and I just finished cleaning the block surface, as well as de-carboning the tops of pistons 1 and 6. I began turning the crank clockwise and got to about a quarter of a revolution and I cannot rotate it anymore. It just won't move. I then rotated it back to TDC counter-clockwise without any problem. When I try to rotate clockwise again, it won't budge. Kinda concerned here. Am I missing something simple? Like the tranny needs to be in Neutral instead of Park? Or, something terrible like a hydro-lock?
Chock the wheels and put the transfer case in nuetral. Belt off the drive line and ac compressor.
The AC belt is now loose. Still stuck. When the head was on and I was checking/adjusting my timing I don't recall ever putting it in neutral, and was able to turn it by hand. With the battery out, is there a way to put it in neutral?
I think theres a button on near the gear selector that lets you change gears while the battery is disconnected. Key in the ignition for that I think.
I'm trying to imagine what else could be the issue.
Hey mate, can't be hydrolocked with the head off. More than likely the timing chain has got stuck/binded up preventing it from turning...
You should be able to turn the key to the run position. Press on the brake, Put transmission in neutral then put your transfer case in neutral as well. That will isolate binding in the drive train if it is that.
I was able to put both the tranny and tcase in neutral, but still cannot turn the crank.
I'll keep playing with the timing chain and see if I can get it unstuck.
I'd guess timing chain or a random idea is that you put a socket on the flex plate to aid in removing the harmonic balancer and forgot to remove the socket.
Oh my this has nothing to do with the tranny or tcase, you need to hold the timing chain and gear up in the air tight then rotate by the crank, you are binding up the chain. I can post a pic if you don’t understand. @mdawg
^^^ This. Your chain is dropping down as you try to rotate the crank. As it moves, slack in the chain will cause it to not align with the sprocket gear at the crank. There is narrow clearance between the sprocket and an oil splash on the bottom of the timing chain cover. Don't force things otherwise you may damage the aluminum timing cover or the sprocket gear.
If you read the factory service manual, one of the first things that they tell you to do before removing the head is to zip tie the timing chain in place to prevent it from dropping down - for the very reason that you have discovered. In addition, there is a bright alignment link on the chain that is supposed to match up with a mark on the top timing gear. If you have created slack in your chain by rotating the engine in a reverse direction, you run the risk of skipping a tooth and not aligning that timing mark with the crank.
Take a look here for an example of what can happen:
1994 1fz-fe Timing chain installation, alignment and timing questions. - https://forum.ih8mud.com/threads/1994-1fz-fe-timing-chain-installation-alignment-and-timing-questions.789240/
Thank you all for the replies. I believe you are all correct about the timing chain. I have now tried holding the sprocket and chain up and tight and tried turning the crank by hand, but no movement on the crank. Hmmm, I think I see where this is going now. What are my options here? Is my only path here to pull the timing cover and fix down below?
Adding to what everyone else has said.
The chain has got to be bound up in there. Cut the zip ties and also try reversing you direction a small amount while holding the chain taut. It sounds like a link is bound up on the crank. Trans/ t case have no affect on this. Don't bother putting things in neutral.
Wow, that did it! I just had to turn the crank counter-clockwise a hair while holding the sprocket tight and it popped right up. Man, thanks for that, guys... whew. Thank you for taking the time to set me straight on this. Appreciate ya!
just make sure that you double check the timing when its going back together, dont want to be off a link and figure that out when your all wrapped up
Yes, listen to @bigredmachine .
Glad you got the chain freed up!
You are not quite out of the woods yet. You need to reset the engine to TDC on the compression stroke and then check the alignment of the links with the timing gear. The bright link should be aligned with the mark on the camshaft timing gear. That mark should be at the top of the camshaft gear at the 12 o'clock position. If the gear is clocked to one side or another, you may have skipped a link down at the crankshaft gear. Since you don't have the timing cover removed, you can't visually confirm that the second bright link is aligned properly down at the crankshaft gear. Make sure everything is aligned before you try to start the engine up the first time.
Sounds like you've got it. Just double check everything.
Good Luck!
