- Thread starter
- #81
Finished getting her plumbed back up and fluids filled.
Yes, and it also leaves you with a fondness towards that FSM!There is a very incredible feeling of satisfaction when that start-up occurs and you know, deep inside, you did everything correctly and the 1FZ-FE responds in kind with confirmation of your efforts and hard work.
It's a gratifying moment. Very few moments that resemble this in our lives.
I pm'd gsi18867 and got some valve cover painting advice. I did prep, prime, color, clear all last night in the garage. Probably too many fumes...
Oh yes, definitely. I did an oil and filter change at around 400 miles, maybe less. Got Rotella in there now. Next up I'm going to flush out the radiator and block for the same reason.Glad it's working out for you. I would like to erge you to change the oil soon. There will still be remnants of coolant in the oil due to the HG failure. The coolant will show up as sodium in the analysis and can accelerate engine wear.
This was my experience when I sent a oil sample to blackstone 3500 miles after a head gasket failure, repair and oil change. The engine was running great but blackstone informed me that my oil contained a small amount of potassium and the iron and aluminum numbers were more on par with oil used for 4700 miles. Not a major problem and I know that oil is not as cheap as it used to be, but if I ever do another HG I will do two oil changes soon after she's up and running again.
How did you cover the letters to not paint over them?I pm'd gsi18867 and got some valve cover painting advice. I did prep, prime, color, clear all last night in the garage. Probably too many fumes...
