- Thread starter
- #61
Crank bolt secured. Thanks SBman. 300+ lb/ft. torque!
A couple of Toyota LC pros are involved with this project. The deck was in good shape. I don't know about the pitting you're referring to. This is the second 1FZ-FE HG I've done so I had that one to compare this block with. All of us have to decide how far to go on a job like this ($$$), and as you can see here I left the 150,000 mile bottom end alone.Why didn't you deck the block? It looks like the gasket cooked the surface similar to mine. I also had a failure on cylinder 1 at the same coolant passage. My block showed similar pitting as yours.
My local experts said I could slap another gasket in there but there would be no guarantee on how long it would last.
Simply valve stem seals would probably take care of that oil issue, but once "you're in there" it's going to keep going. Where to stop is one of the toughest decisions to make. I'm an advocate of not reusing head bolts, for example, but that gets costly all by itself. My $0.02: keep running her. Have lots of fun too.Amazing write up. Also amazing how complex it is. Mine is at 312,xxx miles and I'm wondering how much longer it will go before I'll need the same. I've been thinking about maybe a head pull and rebuild as the valve guides are/must be leaking a bit although oil usage is still low (! qt every 1500 miles or so) and oil pressure is still high.
Thanks for the great write up and pics.
Ned
