I tried out the 851/860 OME spring setup and have got to say, I was pretty disappointed with the amount of rake I ended up with. I realize the 1HD-FT is a little heavier than the 1FZ, but I wasn't quite expecting it to be raked out quite this much. The truck is stock except for 35's.
Here are the before/after fender heights, in inches:
Stock:
Front: 36 Each side
Rear: 35.5 Each side
851/860
FR 36.75 (+0.75)
FL 37.25 (+1.25)
RR 39.5 (+4.00)
FL 39.75 (+4.25)
Questions:
FZJ-80 owners - was your truck raked out with this setup? By how much?
Is anyone running small spacers on the L or R side to even things out? Mine is RHD, so that may be a factor.
HDJ81 owners - what setups are you running to achieve 2-3" lift? It sounds crazy but I'm almost considering a spacer lift as I feel like it'll be more even. I'm not looking for anything too tall since I need to be able to fit the cruiser in my garage.
With the OME springs and stock height:
Stock:
Front: 36 Each side
851/860
FR 36.75 (+0.75)
FL 37.25 (+1.25)
RR 39.5 (+4.00)
FL 39.75 (+4.25)
Questions:
