Happened a few days ago that my starter remained engaged after the truck started. It continued cracking the engine even after I turned the ignition off. Similar to what happened to "83bj60" here:
https://forum.ih8mud.com/diesel-tec...156-hdj81-starter-run-wont-stop-cranking.html
I would like to rebuild it before it gets any worse and needs replacement (good luck finding a 24V starter!). So, I looked up the part numbers for the contacts and this is what I found:
28226-54220 (rebuild kit, Motor side)
28226-54320 (rebuild kit, battery side)
I checked a few dealers and the only part I can get is the second kit (28226-54320).
I was wondering if the terminals in the first kit (28226-54220) are interchangeable with any other Toyota model, or if there's another rebuild kit that can be used instead.
Cheers,
Cheers,
