Just wanted to double check some parts with the community before I put in an order to Partsouq.
Here's the issues I'm having, followed by the part number I'm hoping will resolve them:
Oil Pressure Gauge: Doesn't show any pressure at gauge. Sender has been swapped from used HDJ81.
Sender: 8352060011
Oil Gauge in cluster: GAUGE S/A,TEMPERATUR - 8324460240 or 832446020
(Shows up as Water gauge on partsouq??) Looking for this:
Auto HVAC: #1. Only blows on high #2. Auto function doesn't work
RESISTER,BLOWER: 8713860240 (this is listed as NLA, is there a substitute?)
Found more info on this here: 87138-60222 - Resistor Blower Motor Landcruiser 80 Series
Center Diff Lock: Stuck locked, T-case has been rebuilt, needs new relay
Transmission Control Computer: 8953160010
Gear Light Indicator in Dash Cluster: Park and Reverse light up, Neutral sometimes lights up, D32L Doesn't light up
I actually don't know what to investigate first on a HDJ for this issue. Same as an FZJ? I found a lamp assembly 81850-60481
Sender: 8352060011
