HDJ80 LH 1HD-FT accelerator cable (1 Viewer)
IL
According to Toyota part catalog, the part number of accelerator cable for my 1997 HDJ80 LH with 1HD-FT is 78180-60370.
Unfortunately it is not so easy to find a new one. Does any one know if 78180-60220 that use for the 1HDT will suit?
Good question. I'm wondering what others are doing as well. Ours is a swapped 1hdft & I'm unsure if the jdm cable or 1fz cable was used. Whatever one is on there now is looking kind of rough and the accelerator isn't as smooth as it once was.
I ended up just using the 1FZ one (78180-60280) in my truck to go from the accelerator pedal to the cruise control actuator, and purchased a new 78150-60030 from Japan4x4 for the section from the cruise to the Injection Pump pivot.
Another option "may" be to use the cables from a 3FE FJ80, as those had the same type of dual-cable setup. I am not sure about the lengths or cable ends on those being correct.
