how is the green box attached to the trailer? Is it just welded...
That's pretty darn close to what I have been wanting to build. Wonder if they'd build another w/ same design/features except 102" x 18'? Care to give us an idea of what your cost was?
Elbert,Here is mine...I want to add some metal deck up near the "a frame area" buy the trailer hitch to mount a tool box. Also anyone have any good ideas on a spare tire mount? I guess I got the good deal because mine is missing some of those nice to have things...plus I have large flip down ramps, but thats the way it was and that led to the reasonable price.
I agree with post 68 in regard as to why did I not do this a long time ago...
I would like to have a custom made trailer but I got a real good deal on this one..10.4K GVW rated. Not near as nice as the custom made one.
the good part about trailers in the 10K range or higher is that I have no worry about the trailer...I just drive and the trailer tracks well and I'm not concerned about anything other than just normal maintenance.
Charles,
Do you have any pictures showing the load ramps extended or in use. I'm thinking about doing away with the ramps I have and go to either some type of slide-out or similar ramp that attaches to the rear for loading ut can be locked or secured to the trailer for travel. I'm tired of screwing around with the huge ramps I Have and they make some incredible noise on every bump...espically when trialer not loaded.
ok...
I'm thinking we will remove the large utility type ramps, install a mount for the smaller / shorter type ramps on the rear, and then most likely setup a storage rage under the trailer behind the axles where its flat, right before it goes into the dovetail area. Have a good secure slide in/out type rack and make it where the ramps don't rattle and be able to secure with a tractor pin or padlock. I think from what I've seen probally ramps in the range of 3 to 4 feet would be ok and easy to handle.
when I say mout for the ramps on the rear of the trailer for loading....it would appear that a lot of folks are using small piece of c channel or potentially angle iron to create a lip for teh loading ramp to hang on for loading purposes.
I may go looking around tomorrow with the camera for some ideas.
