having carburetor problems on fj40
Discussion in '40- & 55-Series Tech' started by martytx1234, Mar 3, 2007.
  1. martytx1234
    martytx1234
    1
    Mar 3, 2007
    i am having carb problems on my 79 fj40. does anyone here know of a mechanic in the houston area that knows landcruisers?
    when i adjust the fuel/air adjustment screw, there is very little response. i can even remove it completely and the engine will keep running with out much of a difference. because i cant adjust it i cant get the idle right. any ideas?
    thanks,
    marty
  2. Pin_Head
    Pin_Head
    14,554
    2,196
    Feb 6, 2002
    OC, CA
    That's not surprising. What would be surprising is if you turned it all the way in and it still ran.
    So what makes you think you have a problem?
    Sorry, can't help you in Houston.
  3. cruiser88
    cruiser88 SILVER Star
    11,879
    Media:
    3
    Albums:
    1
    286
    Feb 21, 2006
    Winston Oregon
    most normally if you have to mess with a idle/air mixture screw your only covering up a another problem.unless another was in there rednecking:D .sorry cant help on the location :beer:
  4. DSRTRDR
    DSRTRDR I can mangle anything ... SILVER Star
    14,356
    Media:
    42
    Albums:
    1
    1,529
    Jan 4, 2005
    Baton Rouge, LA and Fountain Hills, AZ
    no help on Houston, but is your timing right?
  5. 65swb45
    65swb45 Elder Statesman Supporting Vendor
    22,544
    7,338
    Apr 14, 2004
    818-953-9230
    If you're looking for a local to look at it, try posting in the TX-Houston forum here on MUD. It's a pretty strong club from what I here.:)
    As far as the carb goes, look down into the venturi with the carb running. You should not see ANY gas coming out of the emulsifier at idle if it is working properly. If there is gas, chances are the idle circuit is not operating properly, and the idle speed screw has been overtightened to compensate for it.
    Best
    Mark A.
