Have OME 2.5 Medium swaping for OEM shocks (1 Viewer)
OC, CA
I have a 2005 LX with OME 2.5 Medium 2860 installed. After a year i want to goto something softer and found OEM shocks might be for me. I found the following part numbers when searching but not sure if they fit my 2005. I cant check my my specific year since its an LX and when I put 2005 LC these part numbers says they dont fit.
Anyone have part numbers for 2005 or will it fit?
GTV
Si'ahl
It's saying it won't fit because the LX didn't originally come with standard shocks.
Wandering the Wild West
Yep. The listed part numbers show correct for 100 series.
However, with the 2.5 OME lift on there, I'd be worried the stock shocks might be too short--at least in the rear...?
OC, CA
While researching on the forums I found many members running this setup. Apparently there is no true "lift", shocks are same length outside of icon stage 3's, from what I've read. If i lose half inch of droop in the rear im ok with that. I cant stand feeling the small bumps with OME anymore. Roads arent getting any better.
