hatch shocks
Discussion in '60-Series Wagons' started by BlueBoxFJ60, Aug 25, 2006.
  1. BlueBoxFJ60
    BlueBoxFJ60
    378
    1
    Jan 18, 2005
    Magnolia, TX
    i have a new set of hatch shocks. How do i remove the old ones??
  2. Jan-78FJ40
    Jan-78FJ40
    3,794
    481
    Sep 6, 2002
    Have someone hold the hatch all the way open, or put a stick in there.
    then you can take the old ones out with a 12mm wrench-you'll see the nut directly where the struts go into the metal of the hatch and rear of the truck.
    that's all there is to it.
    j
  3. beaufort-fj60
    beaufort-fj60
    4,511
    Media:
    10
    Albums:
    1
    11
    Feb 5, 2005
    48" stick works good from bottom door hinge to rubber gasket on the top window.
  4. PAFJ
    PAFJ
    1,644
    Media:
    17
    Albums:
    1
    5
    Jul 27, 2005
    Roseville, CA
    AFAIK once the strut is removed, the only way to seperate the strut from the ball stud is a bench grinder. Or just buy some new 5/16 studs and tap the holes. I did this recently...bought some new struts from Reid Supply, ended up just tapping the holes for new studs...the thread pitch is almost identical.
  5. overhanger
    overhanger
    1,070
    253
    Jun 11, 2004
    Simply pry the original strut off of the ball stud with a pry bar, screwdriver, whatever. Leave the ball stud attached to the hatch. A 2x4 can act as a lever point and protect the paint at the same time.
  6. Jan-78FJ40
    Jan-78FJ40
    3,794
    481
    Sep 6, 2002
    I though the toyota struts came with the balls and bolts attached, when you buy them new...
    j
  7. WagonsRule
    WagonsRule
    157
    Feb 23, 2006
    I changed mine recently. I got the replacements from JT Outfitters. I know nobody likes them, but they were brand new, cheap, and they came with the balls and bolts attached.
    The problem I had was getting the old ones off. I put a wrench on the old nut, put just a little force on it, and the nut pretty much disintegreated. It was very soft. I just used a pair of small vice grips. It wasn't easy to get enough bite to get them off, but it wasn't bad either. I sure like to be able to open the hatch and load or unload the cargo area without giving myself a concussion.
  8. overhanger
    overhanger
    1,070
    253
    Jun 11, 2004
    Don't know what JTO' price was but you can get everything you need from Reid Tool for less than $50 for the pair.
  9. WagonsRule
    WagonsRule
    157
    Feb 23, 2006
    I paid less than $70 for the pair delivered. Got 'em off Ebay. New OEM are over $100 per side.
  10. BlueBoxFJ60
    BlueBoxFJ60
    378
    1
    Jan 18, 2005
    Magnolia, TX
    I didn't buy them new they are coming off another 60 of mine.
