I would remove the other 5, one at a time of course, and verify that the serrations are where they are supposed to be. The FSM tells you which side to turn on each one (it's not the same for every bolt/nut combo). If you don't have the FSM then the instructions on Delta Vehicle Systems website for installation of thier radius arms has the correct procedure.
Delta Vehicle Systems - PRE-ORDER FJ/FZJ80/LX450 2/4/6" Front Radius Arms
If your rig is lifted, you NEED to fix the caster! Make sure you get all the extra flex your lift offers by installing our narrower arms.
www.deltavs.com
