Has this happened to others?
Content may include affiliate links. Please see terms for details.
Eastern Washington
I would remove the other 5, one at a time of course, and verify that the serrations are where they are supposed to be. The FSM tells you which side to turn on each one (it's not the same for every bolt/nut combo). If you don't have the FSM then the instructions on Delta Vehicle Systems website for installation of thier radius arms has the correct procedure.
MyTwoToys
Southern Maine
At the OP, use these.
I am running the Land Tank Castor Correction plates with an Old Man Emu (OME) 2.5 inch lift running 33" Mickey Thompson tires and they work very well. I would recommend them for sure.
Good guy to do business with as well.
Knoxville, TN
That bolt is in shear. If it "snapped" it would have had to have to have sheared off and the shank would still be in there. It looks like it was not tightened correctly and it just fell out. You really don't even need a bolt in this application. A clevis pin and cotter key would work. Torque is not required other than to keep it from falling out and not rattling around.
Dave 2000
Not all Land Rovers are useless!
Spain
Total vehicle weight on arms before the bolts were tightened?
Bolt holes on both side of arm round and not elongated?
Correct OE bolts fitted, remember replacement bolts that do not have the correct tensile strength fitted?
Anti roll bar working correctly, if not too much flex, although unlikely.
Regards
Dave
Broski
I love Wheelin my 80
Morro Bay, At the edge of the Pacific ocean
This is not true. Running the bolts loose will cause the holes to oblong from there you’ll start hearing noise under torque conditions they need to be tightened to the proper factory service manual specifications.
mudgudgeon
Resident galah
Hanging on to the underside of the flerf
I don't agree.
Mr Toyoda certainly didn't agree, torque spec is 127ft,lb
Loose bolts allow a lot of movement at the diff housing causing the housing to clunk as torque shifts the housing under acceleration and deceleration. And you get creaks in the suspension.
As above, holes can end up slotted too.
Killeen, TX
I don't agree.
You guys are talking about things that are above my pay grade. I have sooo much to learn about these rigs. I feel like I’m back at the beginning of when I was learning about building and maintaining custom Italian motorcycles. I’m glad that I like to learn, and I’m incredibly appreciative of Mud members’ willingness to share their knowledge. Thank you to everyone who’s responded to the thread.
