has anyone successfully fixed a rear wheel lock-up scenario under hard braking?
Look up combination valves. I think the OEM ones are true combination valves. The common proportioning valves just try to limit the pressure to one circuit. A combination valve is different.
I'm not going to say it's fixed but it works better if the prop valve flow is correct. Since I started making the hard lines at the frame and was working my way toward the master I just intuitively made the bracket to position the "in" on the side i was working from.
I redrilled my bracket, made a new line, and bled at the master again. It's better, but rear still locks first as far as I can tell. I didnt get to try it on wet pavement or gravel yet.
when i was just a youngling around 17 or 18 , on my first FJ40 1978 ,
i bought all new wheel cylinders at TOYOTA dealer where i worked part time after skool ,
on saturday morning i dove in with 2 feet , by dinner time i was done , or so i thought ?
i went for a test drive and the rear brakes locked up like you would not believe
INSTANTLY !
the truck lurched side ways and almost rolled over more then one time
after a few days of head scratching and panicing , my dad gave the family mechanic a case of natty boe beer to come over and look at the brake job i had done so perfectly i thought ?
- he said , SON your top shorty shoe is NOT forward , ?
i say huuuuuuuuh ?
it turned out i had installed all the wheel cylinders on there wrong locations and upside down ....
you can actually interpret the FSM to do just this .,...
my shoes were on upside down on both sides
easy fix , sorta ....
long time to figure this out for sure
INSTANTLY !
i say huuuuuuuuh ?
Roma has the later +80 setup with the single wheel cylinder
Yes. My 40 was like this when it was stock as well. As a matter of fact I think every 40 I've owned that had working brakes locked the rear up first.
I have a 83 BJ42. everything is stock and in excellent condition. It too will lock the rears first, on all surfaces.
