- Thread starter
- #21
Keep in mind, when you back off the rear brake adjustment it effects pedal height.
I'm not backing off the rear adjustment don't worry I know better.
Note: This feature currently requires accessing the site using the built-in Safari browser.
FJ60’s have the same front brakes. I think @mattressking is on it
@roma042987 what master cylinders are you using? I like to use the FJ60 / 80-84 FJ40 master cylinder
I did a 40 with this setup but with stretched wheelbase and it wasn’t an issue.. about to do two more but with stock wheelbase. Should be interesting to see if it’s different
Could try the larger front calipers from a 4Runner … give you more stopping power up front
Had you got a good grippy semi metallic pads on the front? Your not running ceramic up front are you
And the rear shoes use the worst lol
I don’t think you can get ceramic for the shoes but cheapo hard organic shoes would have less bite if your running semi in the rear
I have 16"s so perhaps I may have clearance.Disclaimer…
I have not done the 4Runner calipers in the front but am contemplating one day doing it … they will rub on 15” rims so they need some grinding
The upgrade comes recommended by mark w and fj40jim to aid in bias issues
I didnt know you were using an aftermarket valve what kind of fluid pressure are you getting at the wheel cyls? I have always used 76+ disk drum master with oem valve. never had an issue. The oem ones like to stick80 series disc/drum non abs master.
The ports are a good question....I've been reading some threads with mixed opinions as to which port is for which circuit. I ran my front port to my front circuit.
Adjustment on the rear isn't the issue. I promise![]()
I am not sure of this "volume" issue. If the master has a full reservoir, and the master stroke pushes -for example 10 cc''s of fluid into the system, the wheel cylinders should move 10ccs of fluid(front/rear--if they don't the wheel cylinders have a volume greater than the master--This would indicate required adjustment of the wheel cylinders to affect contact with the shoes/calipers for the amount of fluid produced by the master. The proportioning valve in my mind is un-necessary--this is a closed system, and as such when it is pressurized. the pressure is applied equally in all circuits that are connected.--If the pedal goes too far , there is a maladjustment of either the shoes or the calipers(assuming no leaks)Are you using the 77 master cylinder or later model? If using the 77 but then the single rear wheel cylinders, sounds like you effectively halved the fluid volume needed for the rear to work but are still providing the same amount?
Is the proper port on master cylinder going to the proper axle?
I could lock up my rears before the fronts, but then I backed off the rear adjusters until they locked up all 4 evenly (77 style double rear drums and 4Runner front discs). I don’t consider that a band aid fix, I consider it proper adjustment for the system.
I don't have any way to check pressures. O.E. valve was froze and I chunked it in 2012.I didnt know you were using an aftermarket valve what kind of fluid pressure are you getting at the wheel cyls? I have always used 76+ disk drum master with oem valve. never had an issue. The oem ones like to stick
Parking brake is purely mechanical and has no connection to the fluid wheel brakesThey're adjusted properly. With the single wheel cylinder set up there is no guess work. Loosening them may yield a "band-aid" improvement while sacrificing parking brake performance. Not my goal here.
You make sense to a point...calipers don't have adjustment and the rear shoe adjustment should not cause inadvertant lock up unless they are grossly over tightened to the point of dragging...which is not the case. Prop valves are necessary for precisely the reason I started this thread. Mine is just not effective "enough".I am not sure of this "volume" issue. If the master has a full reservoir, and the master stroke pushes -for example 10 cc''s of fluid into the system, the wheel cylinders should move 10ccs of fluid(front/rear--if they don't the wheel cylinders have a volume greater than the master--This would indicate required adjustment of the wheel cylinders to affect contact with the shoes/calipers for the amount of fluid produced by the master. The proportioning valve in my mind is un-necessary--this is a closed system, and as such when it is pressurized. the pressure is applied equally in all circuits that are connected.--If the pedal goes too far , there is a maladjustment of either the shoes or the calipers(assuming no leaks)
Now I have concerns as well. Looking at almost every diagram of dual circuit master cylinders, the front port goes to the rear brakes.80 series disc/drum non abs master.
You brake, the frt dives down and rear lightens up, and the rear brakes lock up because there's minimal weight on the rear.
Yeah, I read that same thread a couple of times before starting this one....it's about as clear as mudNow I have concerns as well. Looking at almost every diagram of dual circuit master cylinders, the front port goes to the rear brakes.And this shows the same thing and then it doesn't. the confusion is real. Front vs Rear ports on master cylinder? - https://forum.ih8mud.com/threads/front-vs-rear-ports-on-master-cylinder.1244078/
But in a half hour of research, 95% of tech articles say the rear piston is primary and goes to the front brakes. It starts building pressure first then starts moving the secondary piston.
Thanks Johnny that yellow one is a fake gaucho but I have another authentic one that is 24v. They belong to my 2 and 4 year olds. My conclusion of the 80 master debacle is that the abs ones are backward and the non abs are not. My master is non abs so that shouldn't be my issue. I may swap the lines at the ports this weekend and just give it a try for curiosity's sake.Nice gaucho I got me one of those as well
On a dual 40 master it is definitely front res goes to front brake lines and the inboard/back reservoir definitely goes to the rear brakes … however…
I did a look around at 80 masters parts diagrams and it does look to be reversed … front to back and back to front … as @h82crash said above
May want to have somebody confirm which line goes where on the 80 master
Yes Eddy all the later trucks including the 40s got LSPV's for this reason.The load-sensing prop valve from a wagon would be pretty easy to retrofit as an experiment. Some or all 60 and 80 series came with them. Not sure if one from a minitruck would work or not, but seems like, and they're dirty-dirt cheap.
I was going to do this, but I have an 80-series master with rear 80-series disc brakes and a stock fj40 prop valve and it just happens to work fine. My fronts will lock just before the rear on pavement and about at the same time on dirt.
