Has anyone relocated their windshield washer reservoir?
I asked this same question few weeks ago, no results yet. Im going to attempt to reshape the stock one in an attempt to clear the tire with a heat gun. Will post the results.
For science. Godspeed
Has anyone drained their windshield reservoir on their lc100? Need to replace it with something that does not freeze.
Cut it! Then epoxy, glass it, etc. then spray paint it/bed line it. If you’ve already modded your truck quite a bit who cares.
I just bought a small universal one
I forgot to post this after I "modified" my tank to clear tires. I don't think it practical to do this with a tire bigger than a 285/75/18 but I had good luck and have clearance in all situations without a ton of lift.
Tools used was a heat gun, rag and spray bottle with water. I think with a little patience and removing the tank one could yield much better results.
Are you running sans fender liner or was that just for purposes of the photo?
Anyone relocate there reservoir yet? I’m thinking about reshaping mine if not. I’m putting on a Dissent bumper and would really like to clean that area up for aesthetics.
I picked up a dissent front to replace a front ARB sahara and the visible reservoir bothered me. I didn't feel like taking off the plastic would be "better", so reshaped it to fit the reservoir better. This was probably less work than pulling reservoir off and painting it. Probably 1 hour including the beer that I had to pat myself on the back.
I removed the black surround, drew a few chalk lines on how i'd fold it, made a few cuts with some large garden shears, then heat gun to bend the "tabs" together. I glued the tabs, but then drilled a small hole to ziptie them together. Reassembled. You can hardly see it now.
All in all, the front/rear dissent bumpers do a great job with SF street parkers who can't park. I've already had a few people comment that "it hurts more" when they bump into my car when parking.
Still chuckling at nukes reply. There's a good thread in the 80 section that might give you some ideas & cross compatibility : Washer fluid relocation
I thought about trying to move mine just cause it was sticking out after the bumper install, but covered it with Kydex instead.
Do you remember what size kydex sheet you used? I want to go this route rather than trying to mess with reshaping or replacing the reservoir with something else.
That looks pretty good! I just ended up cutting away a lot of that protective sheet. I will probably add kydex to it in the future to protect the resevoir.
I'm looking to try the Delta relocation kit on my LC 100 to make room for a high clearance bumper. I will need to check into an 80 series reservoir.
