Has anyone installed an internal fuel pump/sending unit in a 22 gallon Con Ferr tank? if so what and where did you purchase ?
1978 FJ40 with a plastic 12 gallon under the passenger seat and I added a steel con fear 22 gallon tank behind the rear axle. there is only one "bung hole" in the top of the con fear tank. My ultimate goal is to run both tanks but have issues trying differing methods of this. Any help is appreciated .You could use my in- tank fuel pump mounting kit, and possibly a Centroid electronic sending unit, but I could provide more info if I knew your year model.
looks like pump would work but it doesn't have a sending unit for fuel gaugeCheck out Holley Sniper GPA fuel pump. Pretty straight forward. Available at Summit Racing or ?
View attachment 2536573Ok, You could use my in-tank fuel pump mounting kit with the Con-Ferr rear tank, you'd use the gasket for the pattern you cut into top of the rear tank, you'd want to mount on the centerline of the tank, forward near the front wall of the tank. If you are using your stock dash fuel gauge, which is 120 ohms on empty by 17 ohms when full, then you could use Centroid Products electronic sending unit, their# CGFP-10-12V-120/17-5H. Then with this set-up you could use a double pull-double throw (DPDT) switch that switches tanks and sending units at the sometime with one flick of the switch, easy deal.
I'll dig up that info somewhere and get back with you. Thanksthen you’d have to know the ohms values of the dash gauge you want to use for the rear tank, then I can provide more info.
