I did a search and I didn't find this topic come up. Having taken apart my transfercase twice I know it is built extremely well. Once to rebuild it and the other to install 10% overdrive gears. The case seems similar to the np205 except with an aluminum housing opposed to cast iron.
I have a built Cummins 12v and am guessing it pushes 300-400hp & 600-700 ft/lbs. I have an a343 and a HF2AV behind it. The torque converter in the a343 has taken the brunt of the power up to now, being my drivetrain cushion, but I am swapping in a NV4500. Without that cushion I am now concerned about the t-case. Has anyone ever broken a HF2AV due to overpowering? Also, because the t-case has 10% overdrive gears installed, does that mean it is receiving 10% more power from the engine and the axles and are receiving 10% less? I am thinking about getting the t-case cyrogenically treated, any thoughts on that?
Now, with that said, most would say I need to worry more about my drive shafts and axles. I'm also concerned about these things, but to help soften the blow of the extra power to the shafts and axles, I am leaving the t-case full time to so the power is divided up 50/50 between them. I haven't had any issue so far, but has anyone else?
