I’m having a real hard time tracking down the locker ECU pigtail. I meant to post in this thread yesterday but accidentally posted in one of the many related threads I have open in other windows
. I must have been through them all by now...
I am trying to wire f/r Eaton lockers in using the factory switch. This is in a 97 lx450. I found the rotary dial pigtail no problem right behind the blank slot. But I cannot seem to track down the 16 pin locker ecu pigtail. Looking for the gray one the OP found inside the little body hole behind the kick panel.
So far I have unclipped and moved everything out of the way as best I can. I have felt up and down the harness and have uncovered several unused pigtails but none that are as pictured above or described anywhere else.
Tried to get a better picture but this is what I have so far searched. Everything marked in red I have felt and nothing is buried in the harness. It’s not in the body hole either.
Can anyone point out where this pigtail is supposed to branch off? I am going to search behind the instrument cluster next.
Thanks in advance!
