Harmonic Balancer
Discussion in '40- & 55-Series Tech' started by 74fj40, Jul 3, 2005.
  1. 74fj40
    74fj40
    2,756
    560
    Mar 12, 2005
    Littleton, Colorado
    Hell, having some problems with removing the harmonic balancer, does the bolt come off clockwise or counter clockwise? :confused: also, we rented the puller from autozone and were not sure how to use it :doh:
  2. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    Righty-tighty, lefty-loosy, just like any other standard screw.
    Try putting a wrench on it and fixing the end of it to the frame, then hit the starter moter (well, if you have things hooked up).
    The puller works after the nut is off: two bolts into the screw holes on the harmonic balancer, then turn the center screw on the puller to push the HB off of the crankshaft.
  3. 74fj40
    74fj40
    2,756
    560
    Mar 12, 2005
    Littleton, Colorado
    thanks dave, now the engine is fully apart with the cam and crank shaft out. tomorow we will take it to the manual car wash and clean the head and block.
    thanks again,
  4. IDave
    IDave
    7,167
    Media:
    1
    Albums:
    1
    29
    Jan 3, 2003
    McCall, ID
    Good deal! Good luck on the rebuild.
  5. 74fj40
    74fj40
    2,756
    560
    Mar 12, 2005
    Littleton, Colorado
    thanks
