I was looking at a 94 LC when I noticed that when you engage the front and rear lockers, the steering wheel was a lot harder to turn than the other ones that I have looked at. Steering works ok when you disengage the lockers. What's wrong? ???
That's normal. When you turn, the outer wheel travels further then the inner wheel and the differential allows this. When you lock the differential, the wheels are forced to rotate the same number of rotations even while turning, which mandates that one or both slip and dramatic steering forces are created. Obviously, this is not good to do on grippy pavement. Best to check them on gravel or dirt. Nothing wrong.
OK. I am driving further out of the city limit. It is usually pavement and construction sites here right now. Hey, maybe I can drive over the dirt road these guys were creating! . Thanks Beowulf.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
