Of recent I have had two instances where my 13BT has been very hard to start.
1) Sat over night, about -1c in the morning, glowed hit the key and it has spun over strongly and a little kick then nothing, plenty of cracking later it fired on 2-3 cylinders then after about 5 seconds all were on board.
2) Today, been sitting about 2 weeks 10c ambient, similar to above, cranked strongly and got nothing for 10 seconds or more, Eventually caught on 2-3 cylinders then all shortly after. Shut it off.
Noticed that for the 2 weeks it had held vacuum in the fuel tank, will fix that. Today changed all filters and drained the sedimenter which was more or less empty. Primer pump, unscrewed plunger and started using it, plunger was wet with diesel, leaking up the shaft and never really got rock hard, just spongy.
Start the car a few more times during the day (was still cold, started and shut off a few times) and as usual started on what feels like half a crank.
My thoughts are is maybe the primer pump dead and letting air into the system between the pump and filter? Causing the hard start, this sound reasonable? Any other things to check? Is there a easy way to check the primer pump system for air?
